How do i know if my PSTwo has Progressive Scan activated?
Discussion in 'Nintendo Forums' started by MLAM, Mar 27, 2005.
  1. MLAM
    MLAM
    Dec 16, 2001
    625
    28
    Hampshire, England
    +80
    Forgive me for asking such a silly question but how do i know whether Progressive Scan is activated on my new Slim line PS2?
    I've read through the manual and it says its in the DVDPlayer section in the configuration menu but there is nothing to select.
    Do i actually need to connect up a component cable to the console first?
    Thanks in advance
    Michael
  2. Pooon
    Pooon
    Dec 26, 2002
    7,128
    Canterbury, Kent
    +731
    In the settings menu(turn console on without disc in drive) then you need to change the video output from RGB to Y, Pb,Pr and connect a Component Video Cable to your Tv and then you will get Progressive Scan from compatible games.
