Pack Dude
I am hopping to improve the sound from my pc which I use for music and also as a HCPC.
I am using the SPDIF output of a Soundblaster Audigy soundcard connected to a Denon AVC A11SR amp using a cable that I think was meant for a subwoofer, its made by SOXI.
Would I hear any improvement if I changed to another cable?
Soundcard, I am happy to use the amp to do all the decoding so I only use the digital output. Is there a soundcard with a better digital output or do they all more or less do the same thing?
I am using my old speakers Tannoy 611s front a Yamaha centre speaker and missions for the back, I guess this is the weakest part of my setup, but I am used to the sound from my Tannoys which I have had for almost ten years and will be sorry to see them go.
I was going to buy a 5.1 speaker setup but I want to put music first. Can anyone recommend some speakers for the front three hopefully magnetically shielded? And also back speakers? I only want two at the back for now.
Is there something else I should be thinking about?
Thanks for any help
Thanks for any help
