how do I improve on 1:2 macro?
Discussion in 'Photography Forums' started by Wingless Garuda, Apr 28, 2007.
  1. Wingless Garuda
    Wingless Garuda
    Feb 24, 2004
    65
    11
    Anstruther
    +4
    I'm looking for some advice. I've got an old, manual focus/manual aperture Vivitar 135mm f2.8 Macro cheaply on the bay (well, I believe it's macro. The lens just says 'close focusing' but the lens barrel is marked and shows that it goes down to 1:2). I thought that 1:2 would get me well into macro territory, but as you can see from the piccie of the 50p piece it doesn't get me terribly far into macro - the shot is full frame. So to get pictures of insects, I will have to extract partial frames.
    Camera = Pentax k100d
    I want to get insect shots, so should I:
    a. get extension tubes and use them with this lens (or the standard 18-55 zoom). OR
    b. get a proper 1:1 macro lens like the Pentax D-FA 100mm Macro, or the Tamron 90mm Macro?
    Thanks for any advice
    [​IMG]
  2. Brammers
    Brammers
    Feb 27, 2007
    852
    43
    +150
    Get one of these!!!
    http://www.pbase.com/pganzel/maxxum_3x1x_macro
    Seriously, get a macro lens. Either of the 2 suggested should be fine, I have no knowledge of the Pentax one though. There's also Sigma's range of macro lenses which should be available in Pentax flavour, I think they do 50, 75, 105 and 180mm macro lenses.
    Macro actually starts at 1:1 magnification. With the age of close focusing zooms, someone started to mark them 'macro' and nowdays even my ultra-zoom Sigma claims to be a macro lens at 1:5.3 magnification. Your Vivitar gains respect from me by only claiming to be close focus - something the majority of 'macro zooms' are today. A true macro zoom is the one I posted above!
    Tubes are fine, but they're very unwieldy and the lens is likely to end up very close to the subject. Most people prefer to keep a degree of distance between the end of the lens and their subject to avoid disturbing insects etc. Tubes will make this difficult to achieve.
  3. Biscuit761
    Biscuit761
    Feb 1, 2006
    3,310
    +507
    I have had some quite good results from my £4.99 ebay screw on macro filter
    [​IMG]
    [​IMG]
    [​IMG]
    Bill
  4. Wingless Garuda
    Wingless Garuda
    Feb 24, 2004
    65
    11
    Anstruther
    +4
    Thanks chaps,
    Food for thought. Biscuit, especially like the tadpole picture :thumbsup:
