How do i improve my sky picture Quality
Discussion in 'Sky Digital TV Forum' started by philinman, May 22, 2003.
  1. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    Since i have had my telly PF1 36Inch the quality on sky is not always great i get colour merging ect etc on bbc1 itv and some music channels.
    I have tried all the leads ect and on dvd i cannot fault it
    So how can i inprove the sky quality i have read about band width ect but i am unsure of what to do .
    thanks in advance :clap:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Try getting a better quality Scart makes a big difference with sky. Have your dish realigned, get the cable up-graded. A larger dish, Better gain LNB.
    I assume you are Using RGB out of the skybox. Try a new Scart a QED or Ixos RGB fully wired scart to scart is about £35-40 but there some on ebay for £20. See if that helps then i think try the dish alignment if its been up a while it could quite off.
    Try looking here http://www.avforums.com/forums/showthread.php?threadid=80404
  3. DaveP
    DaveP
    I dont know if you have anything else to connect up but if you only have the DVD and Sky+ make sure you connect the TV output from the DVD scart into the VCR socket on Sky box and then connect the Sky TV output to your RGB enabled scart socket on the tele (normally AV1).
    As Hornydragon says, make sure you have RGB set on the services/video menu on the sky box.
    One way or another, it sounds like you haven't got RGB showing on the screen.
    DaveP
  4. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    Hi am using rgb output and i am using monster cable scart leads
    current conection is
    Sky box Sony - Sony DVD player - in to RGB on TV
    Sony DVD player has RGB IN /OUT 2 scarts ( i think thats right but i will check when i get home )
    its only some times i get picture probs i had them the other night on cutting it as well as on Tomb Raider last night
    :confused: :confused:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    SOunds like an actual Signal issue get the dish realigned or a new LNB if your is 3+ years old
  6. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    no its just 14 mths old
  7. redmax
    redmax
    Sep 13, 2002
    1,079
    ESSEX, UK
    +43
    Hornydragon
    Can I ask why a 3yr old LNB should be changed?
  8. Fernsehman
    Fernsehman
    It's cheaper than an MOT. ;)
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    early digital LNB's are subject to corrosion etc and are often lower gain than newer ones. Depends on the LNB that was fitted at the time and the condions you live in I have seen some with very rusty conectors from seaside areas etc
  10. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    thanks for your help i have just ordered sky+ i thought i would give it a wirl to see what its like as you get a month
    Also this means i will get a new lmb and setup :clap: :hiya:
