How do I get videos from my camcorder to my computer?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by AznCrew8317, Jan 1, 2005.
  1. AznCrew8317
    AznCrew8317
    So i'm not really tech savvy, but i really need the help.
    So I have a JVC GR-DVL820U and I simply can not figure out how to get my recorded footage (Mini-DV) to my computer. I tried plugging in the mini usb-usb cable that came with the camcorder to my computer, but that only allows me to pull the pictures off which i could already do by putting the SD card into memory card reader on my computer.
    I'm so confused, anybody think they can help me?
  2. Samoz
    Samoz
    To capture video there should be video output from the videocam. This could either be composite, S-video or firewire. If composite/s-video there will probably have Audio to go withit otherwise you will get no sound. Best starting point is to read the manual if you have it, if not do a search on the internet for it, either on a JVC site or through google. Hope this helps.
    Oh, you will need some kind of a video capture interface installed on your PC. You can install USB capture or Firewire, depending on your videocam output, the latter is much faster and will not drop frames.
    Happy NY!!!
  3. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Do a search on these forums & you will see this discussed many times. If you want to capture reliably to your PC you need to use i-link (firewire).
    If your PC doesn't have it, you can get a PCI firewire card including a 4pin to 6pin cable (which you will also need) for under £10 from places like www.dabs.com
