How do I get the latest SKY+ Firmware
Discussion in 'Sky Digital TV Forum' started by PannyAdams, Dec 28, 2004.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    I've had SKY+ for about 4 months. I had an Amstrad V2 box - that at somepoint got some kind of firmware upgrade that allowed me to do interactive stuff during live Pause and allowed me to select which Footbal First match I want to record etc...
    The problem is, the Hard drive failed in it and SKY have replaced it with a reconditioned Pace v2 box. The box looks new in every way, but the firmware doesn't let me do the things the old one used to. Is there some kind of installer setup to force a firmware update?
    BJ
  2. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    ok, this is wat u do..... read the guide through BEFORE u do it ok?
    turn on tv. NOT SKY
    turn off sky box at plug
    count to 10
    hold down BACKUP on THE BOX not the remote.
    WHILST HOLDING IN THE BACKUP BUTTON turn the plug for sky back on.
    keep it held in, then the tv screen should change (if u have it on scart it should, if on co-ax then you'll need to set your tv to the sky channel first)
    basically a black screen with white writing telling you that it is downloading update!
    it'll take 10-15 mins depending on how big the update is (downloading via dish!)
    once done the box will restart itself and you can see if your interactive stuff is back.
    good luck! let us know how u get on.
    jammy
  3. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    worked a treat!
