How do i get rid of this spy program?
Discussion in 'Computer Components' started by PhilipVass, Jul 31, 2004.
  1. PhilipVass
    PhilipVass
    It comes up messenger service and it is some advert telling me how to erase spyware but it is spyware adverts it is in the windows folder under the name "msagent" and it won't let me delete it but when i try to remove it it says the program is in use ect...how can i remove it...Ad ware wont let me take it away, i'm running XP btw.. thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    try a searh for the file name at symantec and in windows help.
  3. PhilipVass
    PhilipVass
    It's in a folder, when i try to remove it, it keeps coming back...
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    it probably edits a registery value, have a go in SAFE mode and remove cookies etc
  5. PhilipVass
    PhilipVass
    How to i put it into safe mode?
  6. HMHB
    HMHB
    Nov 11, 2001
    27,267
    Nottinghamshire
    +6,156
    When the computer is booting up (just before windows starts loading) keep tapping the F8 function key. It will then come up with a menu offering you safe mode. Be patient when going into safe mode as windows takes a lot longer to load.
  7. PhilipVass
    PhilipVass
    Logged in safe mode, removed the files, did a reboot, the files return and i am getting these adverts again!! what can i do NOW?
  8. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    If they are popups in a grey box that you have to click ok to it might be windows messenger. you can disable it and it will stop them http://www.lantalk.net/disable_messenger.php
    If you have not updated windows you should, and use a firewall.
  9. PhilipVass
    PhilipVass
    Thanks that seems to have stopped them, when you say "update" do you mean go to the windows website and do the auto update?
  10. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    Yep the windows critical updates would be a good idea. There are also two service packs out for windows XP.
  11. PhilipVass
    PhilipVass
    Any ideas how long the install progress takes for these service packs?
  12. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    If on broadband it can take about 30 minutes up to 1 hour or so depending on how out of date your PC is.... on Dial up it can take HOURS (MANY!)
    Or wait a few weeks for MS to release SP2 (Service Pack2) which is a free update that includes all uptdates...... A free CD should be available from MS website soon.
    Incidentally, that pop up is probably trying to sell you software to stop pop up adverts!!! oh the irony!
    Go to google.co.uk and search for ADAWARE program, download it (free) install it, update it, scan your PC and see what it finds (spyware and other junk)
    It sometimes pays to turn OFF system restore before scanning....
    Again, do a search on Google about System Restore (sorry I can't be arsed to type it right now)
  13. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Ad-Aware and Spybot finds that sorta stuff in my computer, you can download them both for free. They usually find different stuff, so I scan regularly with both programs.
  14. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    A guess, about ten hours on dialup :) i think you can get the cd from the miro$oft website. You should be able to download the critical updates separately, some of them can be pretty big too.
    BTW if your using a pirated version of windows the update might stop your pc from working.
  15. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    I´d run the computer in safe mode, scan it with ad-aware+spybot+norton antivirus and see if that works.
  16. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
    These messenger popups are a real pain....
    You'll need to halt the messenger service (which has nothing to do with microsoft messenger).
    Delete everything in the windows temp folder, this is how the messenger ad-ware ususally lurks & re-infects.
    Delete everything in internet explorer cache folder including all cookies.
    Open the windows folder & view the folder by date, are there any recent DLL & exe files in there?
    Run adaware, but update the program first.
    HTH.
    Tim.
  17. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    Also I think that using a firewall (even XP's built in one) will stop the messenger service popups... and anyone who isn't using a firewall with XP is siimply asking for virus infections (and will get one or two very quickly)
    and here's the XP SP1 update disc order form:
    http://www.microsoft.com/uk/windowsxp/servicepacks/sp1.mspx
  18. PhilipVass
    PhilipVass
    I had a go at downloading the SP1 but it failed...!..anyway i got a firewall called 'Zone alarm' which seems to be good.
  19. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
  20. MarkE19
    MarkE19
    Aug 10, 2002
    17,486
    Rainham Essex
    +2,487
    Well I'm at work and my PC has had these popups for 2 days, even when I'm not on the internet. We are behind a high security firewall and I have installed adaware 6 and run it about 10 times. Every time it runs it finds files it needs to remove, if PC has been rebooted it can be as many as 40+ files. I have already emptied all the temp/internet folders etc and still no luck. As I work in IT these were the first things I did, but still no luck.
    The problem is that as a shift worker (look at the time of this post, I'm mad but even I would be in bed by now if not at work!) and others use my PC when they are on shift and I'm not, so I just don't know what they have downloaded etc.
    Oh well looks like the PC will be reburnt from the Ghost image in the morning and hopefully sorted by the time I get back into work in the evening. A bit drastic, but at least I know it will get rid of the problem.
    Mark.
  21. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Have you tried running Ad-Aware+Spybot+Norton Antivirus while in safe mode?
  22. MarkE19
    MarkE19
    Aug 10, 2002
    17,486
    Rainham Essex
    +2,487
    Not on my companies PC's.
    As I said I've run adaware, but nothing else other than the McAfee antivirus software that is always running on all PC's.
    Even downloading and running adaware could get me into trouble for loading unauthorised software onto a company PC so I'm wary of doing anything else.
    Still, I'm quite happy to let others work on the problem once I've gone home to bed. But that's not untill 10:00, so just another 6 hours to go :boring:
    Mark.
