how do i get rid of these annoying adverts?
Discussion in 'Desktop & Laptop Computers Forum' started by Mark P, Feb 11, 2003.
  1. Mark P
    Mark P
    hi there, probably a silly question or an easy fix but its driving me mad.
    when i log on to the internet and dial up to my freeserve anytime, the freeserve homepage loads up, no problem, all going well but then i've started to get 2 or 3 adverts up as well (think its by ysearch.com - all that bumf about casino, loans, etc) which is bloody anoying cause i have to close all the pages etc. is there anyway to stop all this preverbial cack comming up everytime i connect up. i know its not the end of the world but it never used to happen................help please!
    mark.:mad:
    [edited for swearing by nutcase_1uk]
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
  3. Desmo
    Desmo
    Jan 4, 2001
    14,169
    Braintree, Essex.
    +5,831
    Simple, don't use freeserve. Send them an email explaining that you don't want adverts shoved in your face every time you log on so you're going elsewhere.
  4. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    I use something called popup stopper.
    It stops all pop up windows and can be turned on and off at will.
    It does, however, mean that when you click on a link you need to hold the shift key down..or it thinks its an advert and cancells it.
    I find this useful for looking at gaming sites which seem to throw up a shed full of porn sites..!!
  5. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,442
    I use pop up stopper too, you can download for free here.
    Also alerts you to an ad being stopped by various sounds, I use the gun shot which when visiting certain sites ends up sounding like "The Gunfight At The OK Corral" :D
  6. Mark P
    Mark P
    thanks for the suggusetions guys. i think i may use one of those free software downloads. thanks for all your time.
    mod: sorry about the swearing, won.t happen again:suicide:
  7. feet14
    feet14
    Mar 13, 2002
    88
    UK, West Midlands
    A bit OT, but if you're on ADSL and using a router then the router might have options for blocking certain sites. I have mine set to block doubleclick.net,doubleclick.com,ad.uk.* and a few others. It may not stop a pop-up window appearing but it should prevent more loading when you close a pop-up.
  8. Guy Clifford
    Guy Clifford
    Try downloading Ad-Aware (usually one of the top downloads on download.com).
    You'd be amazed how much ad and spyware you can get installed accidentally without realising.
