How do I get rid of the Sky+ buzz ?
PD_BARBS
Established Member
Hello Folks,
I got sky+ installed around a month ago and the buzz, hum, squeal or whatever you want to call it is driving me mad.
The box I have is a Thompson, but I see from this forum that it is not unique to this type of box, or a problem with every Thomson.
The sky engeer came out to look at it today and basically said tough you will have to get used to it, that all Sky+ boxes are like this. To be fair although the service is good, this has certainly not enhanced my viewing experience.
So should I ditch my sky+ and cancel it, or has anyone been successful in sorting this issue out.
:lease:
jay61076
Established Member
Is it the hard disk or fans as it may not be able to stop all noise from the box get Sky back out and try maybe a pace or amstrad box if they are the same then nothing more you could do but worth a try
A
alternate
mine has a vibration buzz problem. If you press gently on the front of the case the vibration stops. Solved it by sticking a couple of DVDs on the top.
PD_BARBS
Established Member
I assume that this annoying buzz is not common to all Thomson boxes and that the sky engineer was full of it.
I'll give it a try, otherwise I'll just get rid of it.
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
