How do I get picture size correct for sky
Discussion in 'Sky Digital TV Forum' started by dugit, May 25, 2005.
  1. dugit
    dugit
    Apr 29, 2005
    93
    Have recently installed diy sky which works OK except that I find the picture height and width too large, by over an inch horizontally and probably a little under an inch vertically.
    I have fiddled around with the format control on digibox and tv set with no success whatsoever.
    My set up is:
    1) Digibox Pace DS430N
    2) Video recorder Thomson VTH 7090U
    3) TV 28" widescreen Ferguson W7023U
    I have connected the three items according to the Pace instructions.
    Any advice/comments would be greatly appreciated.
    Note:
    To compare picture sizes I have switched from Sky transmission to same channel on local land transmitter
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Go to the Services menu under picture settings and select 16:9.
    On the TV, select 16:9 or widescreen.
    Most terrestrial TV is 15:9 so you should see black bars top & bottom on that.
  3. Bluevanman
    Bluevanman
    Some modern TV's have a number of different picture sizes to choose from.My Toshiba for example can be switched between 4:3,14:9,wide,subtitles,cinema and auto. Some remotes have a button on them so you can switch anytime,others require you to use the picture settings menu on the set.
  4. dugit
    dugit
    Apr 29, 2005
    93
    many thanks for both replys which I will try
