How do I get paint splatters off car?
Discussion in 'Motoring' started by lmccauley, May 29, 2005.
  1. lmccauley
    lmccauley
    Oct 24, 2000
    3,318
    Newcastle
    +216
    I recently noticed that the passenger side of my car has a sprinkling of white paint along the bottom half. It's fine from a distance, but I'm in the process of cleaning it up to sell so anyone inspecting it will see it immediately. I think it must have been from when my neighbour had their outside woodwork painted. :mad:
    I can get the odd mark off with my nail, but there must be thousands of them. I tried t-cut on a small patch, but it didn't have any effect.
    Anyone know of some way to get them off without damaging the underlying car painwork, or am I looking at taking it into a body shop?
    Cheers,
    Liam
  2. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    There are cutting pastes moe abrasive than t-cut.Not sure if they are available to joe public.I had a similar problem a few years ago and i took my car to my dealer who used a very coarse paste to great affect.
  3. Member 55145
    Member 55145
    Jan 18, 2005
    12,071
    +3,489
    i know it sounds daft, but if they are droplets use a soft cloth, like a duster and rub VERY hard, should pull em off id of thought, DONT use an abrassive brush abviously lol
  4. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    What a small world it is. I have the identical problem (on the bonnet). The bodyshop at my dealer's has attempted to polish out the spotting but to no avail and says the only solution is to respray the affected areas. I'm confident they're telling the truth as they're highly reputable and I've used them for years.
  5. lmccauley
    lmccauley
    Oct 24, 2000
    3,318
    Newcastle
    +216
    I hope it doesn't need a respray, as it managed to hit 3 panels. :(
    I'll try the soft duster method when it dries up outside.
    Is there no solvent that would work on wood paint, but not affect the paint used on cars?
    Cheers,
    Liam
  6. Member 55145
    Member 55145
    Jan 18, 2005
    12,071
    +3,489
    i wouldnt risk it.
    how much you selling the car for? if its not much i wouldnt bother. if its alot sue the neighbour lol
  7. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    I Managed to cover my car in decking stain a few years ago when i was spraying my front fence with it :oops: Had to get a full respray :( :nono:
    Adrenochrome.
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  9. lmccauley
    lmccauley
    Oct 24, 2000
    3,318
    Newcastle
    +216
    The car's worth about £4k. Unfortunately, I didn't notice the paint until after my neighbours had moved.
    I don't know whether the paint is water or solvent based. It is white (can you tell I'm not into diy...?). I'm assuming that it is outdoors woodwork paint. Is that usually one type or another?
    Cheers,
    Liam
  10. Garrett
    Garrett
    Apr 21, 2001
    33,603
    2
    167
    The best thief you’ll never see.
    +4,472
    Not being a paint expert but isn’t car paint cellulose base and needs cellulose paint striper which is very harsh were house gloss paint takes turps based thinners which is not as harsh??????????????????????
  11. neilneil
    neilneil
    Jan 2, 2002
    720
    28
    +39
    If it comes off with your nail why not try a sharpend piece of soft wood like pine or something, maybe a wooden food spatula?. I'm thinking something that is about as hard as your nails that will scrape off the paint but too soft to actually damage the car paint.
    Then, when the spots are off polish up with a bit of tcut. It can't do any harm as a last resort before a respray. As long as you don't use anything too hard that will damage the surface of the car paint.
    -Neil
  12. Jbev
    Jbev
    Aug 6, 2004
    129
    London
    +4
    Try going to your local Decorators Merchant and look for Painter's Hand Wipes. Try on a discrete area first but it should remove the spots. You may have to put some effort into it though.
    Alternatively you could try a product called Biospirt. It's made from rape seed and takes small paint splatters of the skin with a little work, so it should be alright for cellulose based paint that car's use.
    This may seem a bit obvious but use cotton rag with any liquids as they won't break up like kitchen roll.
    Hope this might help
    Joel
  13. roversd1
    roversd1
    In a former life, I was a car valeter so:
    Dont use paint stripper
    Dont use abrasive pastes as the it will create thin patches of paintwork
    Use thinners such as Finnigan's, a cotton cloth and gentle rubbing action. This will break down the foreign paint nicely. It will als remove tar spots and other sticky stuff.
    Too much rubbing will mark the paint work!
    Its hard work but worth it. Once clean, T-cut & polish and you will never know the difference.
  14. Paul D
    Paul D
    Dec 27, 2000
    2,620
    Manchester
    +391
    I have used "white spirit" in the past.
    Most body shops use this to clean paintwork before applying badges etc.
    It doesn't effect car paint with brief contact.
    Apply it to a clean soft cloth, and gently rub.
    After cleaning a small area, have a clean damp cloth on hand to wipe any excess paint spots and white spirit off.
    Finish by giving the area a thorough rinsing, and then clean and polish as normal. :smashin:
  15. lmccauley
    lmccauley
    Oct 24, 2000
    3,318
    Newcastle
    +216
    Well, I have cellulose thinners and white spirit in the garage. Which would you recommend I use?
    Thanks again for all the advice guys. This forum never ceases to amaze me with the help you can get on all kinds of subjects. It's not bad for AV, either.
    Cheers,
    Liam
  16. Paul D
    Paul D
    Dec 27, 2000
    2,620
    Manchester
    +391
    Do NOT use the cellulose thinners! :eek:
  17. Garrett
    Garrett
    Apr 21, 2001
    33,603
    2
    167
    +4,472
    Ekk that willl remove everything in sight and leave you with bare metal, like above no way use it, it is harsh what you might call paint acid.
  18. lmccauley
    lmccauley
    Oct 24, 2000
    3,318
    Newcastle
    +216
    Paul,
    Can I borrow your avatar while I say "Doh!"...? :blush:
    Cheers,
    Liam
  19. John
    John
    Dec 13, 2002
    11,005
    +2,685
    Does this mean your now going for the polished bare metal look :D
    John
  20. Paul D
    Paul D
    Dec 27, 2000
    2,620
    Manchester
    +391
    Liam, i hope your joking right? :rolleyes: :oops:
  21. lmccauley
    lmccauley
    Oct 24, 2000
    3,318
    Newcastle
    +216
    It's OK, I meant "Doh!" for me even suggesting the cellulose thinners... I've been too busy to have a go at the paint yet. Will try on a small section of the bumper tomorrow with white spirit and see how that goes.
    Cheers,
    Liam
  22. Setenza
    Setenza
    Jun 17, 2002
    3,345
    +226
    Wire wool.
  23. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    Brillo.
  24. Paul D
    Paul D
    Dec 27, 2000
    2,620
    Manchester
    +391
    Nitromors? :devil: :suicide:
  25. lmccauley
    lmccauley
    Oct 24, 2000
    3,318
    Newcastle
    +216
    White spirit didn't do any good. Will take it to a local bodyshop recommended by a colleague next week when I have time. Will let you know the damage... :eek:
    Cheers,
    Liam
  26. Red_TDi
    Red_TDi
    Oct 7, 2004
    552
    Northampton
    +10
    You could try using a clay bar. Its excellent at removing overspray and really hard to remove tar spots. It worth a try.
    You may be able to get it from halfords or somewhere similar.
    Heres a link to some:
    http://www.seriousperformance.co.uk/sp/products/maintenance.php
    Check out the Meguiars Quik Clay Detailing, I think it comes with the spray.
    I've used a clay bar before to remove overspray on my alloy wheel left from a careless bodyshop.
  27. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    100% agree, claying would be my fist choice. If the consumer clay does not work (I am confident it will), stronger more abrasive clay can be obtained. Clay is used by some bodyshops to remove any overspray.
    Clay is easy to use and very effective. I would then clay the entire car and you will be amazed at how smooth the paint becomes
  28. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Bodyshop got rid of my spotting - but only by respraying bonnet, bumper and front wings, a four-day job. Bank account looking very poorly. Liam how did you get on?
  29. hutters
    hutters
    Aug 20, 2003
    710
    28
    Cambridgeshire
    +28
    I'd certainly recommend a clay bar, do the whole car and you will be amazed at how smooth the paintwork is - ready for a good wax coating.
    I'd seriously recommend Swissol, may look expensive, but you use so little it lasts for ages. Paint rubber set is on this page: http://www.swissol.com/E/GB/Produkte_Lack2.htm
  30. Drd
    Drd
    Jan 22, 2005
    1,817
    Approaching the doghouse at great speed
    +246
    Hi guys,can i just hijack this thread for a second.I've always used a cutting polish in such situations.I'd never heard of clay bars.How do you use them,are they purely a mild abrasive,ie do you rub them over the offending piece of paintwork?
    ian
