How do I get my DS online? (Sky Netgear router)
winka45
How do I connect to my router. I had online about a year ago, since then I had to reset my router and now I cannot get online. I cant remember how to do it because someone talked me through it before. Can anyone help?
randan
The Sky Netgear Routers come set to use WPA encryption as standard. The DS doesn't like WPA and cannot use this so you will need to access your router which you can do from a browser page by putting 192.168.0.1 in the address bar. The page for the router should come up and the user name and password should be the defaults for sky which I think are
user admin
password sky
Change the wireless encryption to wep and generate a key then apply it.
When setting up the DS networking, put the same key in. You should then be able to connect.
Kind Regards
