How do i get Documents in the Dock
Discussion in 'Apple Forum' started by cambsno, Jun 12, 2009.
  1. cambsno
    cambsno
    Jun 4, 2006
    238
    +16
    I am sure I had my documents folder in the doc on the right hand side - not there, how do I get it back. Dont want to drag it from the sidebar in Apple HD in case it disappears!
  2. sneakyget
    sneakyget
    find the folder in finder then drag that to the dock.
  3. CamFire
    CamFire
    Apr 26, 2009
    4,694
    Cambridge
    +600
    If you ever find yourself having to do the same for other documents, then create a folder and move into it the aliases of those documents, and move that folder onto the Dock as a Stack folder. Using aliases ensure that you keep those documents at exactly where they are or suitably kept.
