How do i get 5.1 via my pc
Discussion in 'Desktop & Laptop Computers Forum' started by mojo1080, Aug 9, 2005.
  1. mojo1080
    mojo1080
    Jan 27, 2005
    475
    +81
    Can some one please tell me how i can get my audigy2, and my 6.1 creative speakers to actually work in Dolby digital 5.1 whislt playing a film on my pc. Is there a certain codec i need, or do I just have to mess with the setup .Also is there any software that will up scale to a HD rez similar to panasonic dvd player which upscales to 720p etc . If someone can help that would be really cool :smashin:
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,937
    Manchester, England
    +81
    as fara s the scaling goes your video card will automatically scale the dvd picture to whaterver reoslution you are using (for example 1280x720). you could also use a post processor called ffdshow (google) to do a better quality scaling job. what dvd player do you use and what is your display device?
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    When you say 'get it working' can you be a little more explicit? :) Are you hearing any audio at all? Which Creative sound system have you got? Are you trying to get the PC to decode the AC3 stream or are you wanting to output digital via the SPDIF connector?
    Depending on what you're trying to achieve you may have to set one or two options in the Creative Surround Sound Mixer (at least, that's what it's called with my Audgiy 1 system).
    IOW, what isn't working, what have you tried?
    Also, what DVD player software are you using? That's important with regards using post-processor such as FFDSHOW.
    The more info you can provide about your system and problem the easier it is for others to offer suggestions. :)
