How do I get 1280 x720
Discussion in 'Desktop & Laptop Computers Forum' started by oaklandraiders, Dec 27, 2004.
  1. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,049
    41
    Surrey
    +14
    Yo
    Ok so dumb ? , how do I select 1280x720, it doesnt let me slide to that figure just jumps past it.
    Nvidia FX5900
    Downloaded powerstrip but cant get it to recognise settings.
    I've bought a TV/monitor 16:9 so trying to get it right.
    Isnt there a 16:9 option in windows somewhere ?
    John
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Annoying isn't it :) .. you need to poke around:
    1) Go to the Monitor tab of the Advanced Display Properties and un-set the "Hide modes monitor doesn't support"
    2) Go to the Adaptor tab and click "List All Modes", you should now see the new resolution set by Powerstrip and be able to select it.
    Alternatively, NVidia drivers 67.03 upwards (possibly earlier, can't remember now) have a built-in 1280x720 setting, certainly 67.03 added a custom resolution feature that makes Powerstrip redundant for simple resolution/refresh changes.
  3. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,049
    41
    Surrey
    +14
    Yo
    Downloaded latest Nvidia and that let me select it, man alive now its a great picture.
    THanks
    John
