how do i fit a 2hr 46 film on a dvd with tosh x32?
Discussion in 'Blu-ray & DVD Players & Recorders' started by stolt, Oct 31, 2004.
  1. stolt
    stolt
    Oct 19, 2003
    333
    rayleigh, essex
    Hi I own a tosh 32 recorder and have afilm I need to burn several times to dvd when I click on dub selected items and message shows that the film will exceed the space on the disc, I tried a rate conversion last night to HDD in the hope to burn it to disc this morning but I still have the same problem, any suggestions would be greatful.
    thanks
  2. tabatha
    tabatha
    Jun 9, 2004
    180
    16
    West Midlands, UK
    Perhaps you have not set the rate for the DVD record - I think the HDD and DVD rates are set to the same by default when the machine is first powered up from new. You need to go to the AV Record Quality menu - you will see that you can change both the HDD and DVD rates separately.
  3. bobbles
    bobbles
    you recorded it to the HDD at a rate which is too high to fit the film onto a single -R
    you need to do a rate conversion dub HDD to HDD at a rate of 3.2
