Quantcast
How do I find which size VESA screws I need?
MajorMike
I am considering a new Sony TV -AF9 | MASTER SERIES | OLED | 4K ULTRA HD | HIGH DYNAMIC RANGE (HDR) | SMART TV (ANDROID TV)
I wish to take down my current TV mounted on the wall and replace it with this.
In the full specification it mentions VESA Hole Pitch 40 x 20 cm which I presume is the distance between the screw holes on the TV. However it does not mention the size or number of the screw.
Is there a way of finding this?. I have tried searching on the internet but whether it is because this is a new model it does not seem to be mentioned.
Thank-you for any advice
Michael Houghton
