How do I find the Vesa for my Lg.
Discussion in 'Home Cinema Buying & Building' started by soukio, Jan 23, 2008.
  1. soukio
    soukio
    Jul 17, 2007
    35
    :hiya:Hi all. Want to wall mount my daughters Lg 32lc3r. Bought a mount from Amazon, which was supposed to fit the Lg, but none of the holes aligned and the mount stuck out below the level of the lcd. How do I measure the Vesa required for her lcd and are all cheap wall mounts such poor fits. Many thanks, soukio:confused:
  2. Oli1983uk
    Oli1983uk
    Jan 4, 2007
    126
    +6
    I found this web site that lists wall mounts that fit that screen:
    http://www.tvbracketsdirect.co.uk/order.php?action=3&id=182
    hope it helps, Also this is a quick guide to measuring what the VESA is on the tv:
    What Is VESA?
    Shown here are the most common - 75 x 75mm, 100 x 100mm, 200 x 200mm, 200 x 100mm, 400mm x 200mm and the new 800mm x 400m
    To see if your TV meets these standards, look on the back of your TV, you will notice a number of holes which will have a screw thread in. If the distance between these holes measure 75mm, 100mm, 200mm, 400mm or 800mm (See example of 75mm holes below) then your TV confirms to the VESA standard. Over 90% of modern Tv's now conform to this standard.
    [​IMG]
  3. Spectrum Brackets
    Spectrum Brackets
    Sep 11, 2008
    27
    3
    Please look on www.spectrumbrackets.co.uk for a selection of e-visions uk wall brackets including
    flat or pullout brackets,all made in the uk and we always
    make sure each produts has the correct fixing for the screen
    before the order is sent out.
    Assured adtvertisers with good discount for forum users.
