How do i find out the ip address of my computer
Discussion in 'Desktop & Laptop Computers Forum' started by schillaci0, Jul 22, 2005.
  1. schillaci0
    schillaci0
    Jan 18, 2005
    638
    Starting to get where I want to be
    +14
    :hiya: Me again, I an trying to set up remote desktop for my htpc so i can work on it while the mrs is watching crap tv ( extreme makeover etc :rolleyes: :boring: ). I currently connect to the world via wireless so therefor have a wireless adaptor of which i can easily find the ip add for but are unable to connect remotely with my laptop. Im sure it's because of the wrong address. so i think i need the htpc add but do not know where to look :confused: Help ineed a :lesson: before i :suicide: :lease:
  2. smelly
    smelly
    Oct 16, 2004
    1,598
    Bristol
    +102
    Not sure I really understand what you need but if its only the IP for the PC you're on then do Run Command and type IPCONFIG
  3. lisag
    lisag
    Jul 14, 2004
    5,556
    Essex
    +296
    open a command prompt and type 'ipconfig /all' that's how I do it anyway
    lisa
  4. schillaci0
    schillaci0
    Jan 18, 2005
    638
    +14
    Hi lisa & smelly, i had already typed ipconfig and the black box appears for a second and then disappears, also tried ipconfig/all but windows says it cannot find it. I am really at loss today if have seen my other post xp home to xp pro you will see what i mean.
  5. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    Type "cmd" in the Run box. That'll open a black box that'll stick around. Then type ipconfig into the black box .. read the output, your IP address will be in there somewhere.
    Type exit to close the black box.
  6. schillaci0
    schillaci0
    Jan 18, 2005
    638
    +14
    I think the problem may lie in the fact that iam trying to access my network internally.
    Has anyone got any ideas how i can achieve working on my htpc via my laptop screen.
    thanks for the previous posts.
  7. The Dude
    The Dude
    May 21, 2004
    4,822
    Beverley, East Yorkshire
    +1,169
    from the laptop try this:
    start> run> cmd
    type ping yourhtpcname and see what happens.
    Do you get a reply?
    If you do:
    Start > run > mstsc
    then type the name of your HTPC in the box and click OK.
    You should then be asked to provide the administrator password,
    once this is done, you should be in.
  8. schillaci0
    schillaci0
    Jan 18, 2005
    638
    +14
    Thanks dude,
    But I have clicked on one of the links below the thread and setup a remote desktop with these lot https://secure.logmein.com/ and it works fine ( much simpler than microsh*tsoft) so thanks to everyone for there help.
