how do i extend my lamp life?
Discussion in 'Projectors, Screens & Video Processors' started by peter123, Apr 23, 2005.
  1. peter123
    peter123
    i have brightness on 35%
    i have it on eco mode
    i never turn on the projector more than 4 hours a day
    my room is cool
    i clean the lens often
    i always let it cool for atleast 1 hour before turning it on again
    anything else i should do to extend the bulb life?
    is that suffecient to keep my bulb for 3000 hours? considering its a 2000 hour bulb
  2. stripe
    stripe
    Apr 7, 2004
    1,241
    Scotland
    +123
    If it's a 2000 hour bulb hen it will only last 2000 hours, there is a built in timer that will eventually shut the projector down untill the bulb gets changed.
    It does sound as though you are doing everything right to make it see out the 2000 hours.
  3. peter123
    peter123
    it says it can last up to 3000 hours if i use it in the right way
    you can reset the bulb timer on my projector
  4. sillybeans
    sillybeans
    The guide in the faq recommends cleaning the filters once a month. Probably worth doing.
    Mike
  5. Mr Grumpy
    Mr Grumpy
    Jan 12, 2005
    377
    TBC
    +9
    If only all bulbs were created equal eh.
    TBH one of my biggest concerns before plunging into the world of Projectors was premature bulb failure. Now I have just come to accept that it is something of a lottery and that in reality the best I can hope for is that the bulb doesn't fail mid film/footie as that would compound the misery.
