How do I enable RGB on sky+ box?
Discussion in 'Sky Digital TV Forum' started by RichA, May 16, 2005.
  1. RichA
    RichA
    Apr 28, 2005
    49
    11
    Putney
    I read elsewhere that I need to tell the sky to output RGB quality via the RGB scart cable to get the best possible pq.
    Have looked through the sky+ menu system but can find no reference to this kind of thing.
    Is this correct. Does anyone know how this is done. Thanks.
  2. Flimber
    Flimber
    Sep 22, 2002
    13,362
    Yorkshire
    +4,477
    Push the Sky button and use the 'TV' scart (bottom one).
    HTH,
    Mike.
  3. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I'm at work at the moment, but, IIRC, choose the Settings button on the remote and then choose Picture Settings (option 1 I think) - there is an option in there to switch between RGB and PAL.
    HTH
    John
  4. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    In addition to all of the above you also need to have 'scart control' set to on (picture menu also) and dont forget to save settings before yo exit:)
    Wackojacko
