How do I enable 'FAST WRITE' for my Radeon 9600XT ??
Discussion in 'PC Gaming & Rigs' started by BADA55, Mar 23, 2005.
  1. BADA55
    BADA55
    Mar 16, 2005
    227
    +3
    I want to check out some High Definition demos with this pc and unlike my nVidia 6800GT this card has Fast Write on it. The microsoft site say I need to enable it which I found and tried to do in the card settings. Unfortunately after restarting the card reverted back to rewrite disabled? What else can I do in setting to enable it?
    I am running a MSI KT3 Ultra 2 board with an Athlon XP2600 cpu and 1 GB ram....the card runs in a 4x AGP slot if that makes a difference ?
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Erm - The Nvidia 6800 GT has fast write on it - just checked, in the driver it's under the AGP Settings.
  3. BADA55
    BADA55
    Mar 16, 2005
    227
    +3
    oh Ive never looked for it...didnt even know what its for so left well alone.....
    Still I am stuck not knowing how to enable it on my Radeon 9600XT :(
    ANy ideas anyone?
  4. Kramer
    Kramer
    Did you enable fastwrites in BIOS?
    If it reverted back, maybe check for a BIOS update for the mainboard.
    :smoke:
  5. BADA55
    BADA55
    Mar 16, 2005
    227
    +3
    Oops!! I didnt even know I had the option in bios cheers sorted it now but cant see any difference when watching a movie? What do I need to look for? ;)
  6. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    I wouldn't enable fast writes in the bios. It's notorious for causing system problems. Fast writes is one of those "it seemed like a good idea, but it's in fact crap" things. Most IT sites advise against using it.
    It was designed for improving throughput for games not video playback.
    Just my 50p's worth. :)
  7. BADA55
    BADA55
    Mar 16, 2005
    227
    +3
    Funnily enough since I enabled fast write and also dloaded the new ati drivers I do have a little problem ;)
    I dont know if its related or not but whenever I use my mouse pointer over certain areas, like somewhere where I need to click on it so I can start typing, I get a small quarter inch square box covering the normal vertical indicator line. The box is made up of a group of horizontal lines. When this box appears I can still just about see the pointer because the lines are close together. I am assuming whatever I have done has enabled a graphic box that is used for something no doubt but no use to me at all.
    Has anyone any ideas how to make this box disappear??
  8. HMHB
    HMHB
    Nov 11, 2001
    25,601
    Nottinghamshire
    +3,954
    If it were me I would try disabling fast writes first of all
  9. BADA55
    BADA55
    Mar 16, 2005
    227
    +3
    I decided to restore it and all is fine now.
    Does anyone have anything good to say about enabling fast write ???
