how do i do this
Discussion in 'Home Cinema Speakers' started by jelly, Oct 9, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    is there any way to buy a pair of biookshelf speakers and use them as front speakers then in turn use the fs1 fronts as rear centers????? or if you have any ideas
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    surely it is just how you connect them to the amp
  3. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    well no cos the speakers go from the amp to the sub then to the speakers from the sub to the speakers are moulded connecters
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    What connections are on the speakers, on the sub i am slightly confused exactly what goes from amp to sub?
    If I am reading this right you go from amp to sub then to the speakers???
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Which outputs from the amp go where NXT are odd but not that odd!
  6. richard plumb
    richard plumb
    Jan 27, 2002
    14,478
    Windsor
    +1,046
    the 6 outputs from the amp (5 speaker level, 1 sub RCA), connect to a single multi-plug on the Mission subwoofer.
    There are then connectors (non-standard) for the 5 panels to plug into.
    So the sub is only taking in 5.1 channels of information, and the speakers only work when driven from the mission sub.
