How do I connect Y Cb/Pb Cr/Pr ?
Discussion in 'Cables & Switches' started by Aqualung, Dec 14, 2003.
  1. Aqualung
    Aqualung
    Sep 12, 2000
    45
    I presume these are similar to RGB or is there a big difference.
    Also is it possible to solder some cables to the scart output from my DVD and plug them into my projector using these connections?
    I would appreciate any explanation you could give me please on the use of these connections. The projector is a Hitachi PJ-10.
