How do I connect Pace dv3,dvd,and vcr?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Keith B, Jan 2, 2003.
  1. Keith B
    Keith B
    Just bought a pace dv3 freeview box,and I would appreciate some advice on the best way to connect it and a dvd player,and also a vcr.My T.V has 2 scarts,and so does my vcr,and the dvd has 1. Anybody out there that can help or e-mail me a diagram??Thanks!!!
  2. Fernsehman
    Fernsehman
    As you will no doubt wish to record programmes from your Freeview box, I'd guess that you connect it to your VCR via a Scart lead. The VCR then goes to the TV AV2 socket via Scart (and also RF lead for the aerial signal - plug the aerial into your VCR and RF out to the TV). The DVD will most likely go to the TV AV1 socket if that's the one that accepts RGB.
    Then all you have to do is figure out which buttons to press!
    Confused?
    You can also buy a Scart switching box from SatCure but I suspect you won't need this.
    Fman
  3. Keith B
    Keith B
    Thanks very much,I'll go and give it a try!!!!!!!!
