How Do i connect my xbox to my pc?
Discussion in 'Home Entertainment Computers' started by fu19, Feb 9, 2009.
  1. fu19
    fu19
    Jan 21, 2009
    Hey,
    i was wanting to connect my xbox to my pc but have been told that this is not possible, but i personally think it is, i mean it must be coz its just like a hard drive so there must be some way of doing this.
    could anybody help me, or is there bno way to do this.?
    thanks.
  2. TylerDurden
    TylerDurden
    Nov 6, 2005
    4,140
    +622
    Are you talking xbox or xbox 360 ? Why are you trying to connect to a PC ? To play on your monitor or to access data on the xbox ?
  3. fu19
    fu19
    Jan 21, 2009
    Xbox 360.
    to play on my monitor and data.
    i thought it would be a case of getting a few usb cables.
    thanks.
  4. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,595
    +920
    No real way of connecting the XBox to your PC to use that monitor other than a TV capture card (which will have lag)
    The 360 has a VGA cable which would let you to connect directly to your monitor - if you bought a VGA switch you could switch the monitor between your 360 and your PC.
    The 360 can also be networked to your PC over an Ethernet or WiFi connection (if you use the MS WiFi adaptor) to allow you to use it as a Media Center extender (i.e. watch TV streamed from your PC to your 360) WiFi not good for video streaming - but fine for audio. 100Mbs Ethernet fine for both.
