How do I connect my xbox to my cable modem?
Discussion in 'Xbox Forums' started by tony kop77, Nov 26, 2003.
  1. tony kop77
    tony kop77
    Sep 27, 2002
    6,169
    103
    Northamptonshire
    +276
    I have just bought an xbox and would like to know the best way to connect to broadband please.
    I have an NTL cable modem connected to my PC via ehternet what is the best way to connect the xbox to the modem.
    NTL are doing a deal where pay £5 extra and they will give me an extra OSP address so I can use the PC and xbox at the same time. NTL will also offer discount on games up to £10 off new releases and offer 3 issues of the offical xbox magazine.
  2. othello
    othello
    Oct 9, 2001
    147
    16
    england
    i just unplug modem from pc then plug into xbox.. i`m with nthell to.. thing is i have to unplug as i have no more sockets to plug everthing in... i need 4 for xbox tv amp subwoofer.. then pc modem, monitor,sound+sub for pc.. so the eleccy would love me if i had all thoughs plugged in.. if i`m on pc then go to xbox i have to turn modem off then on again..must be something to do with ip addy i think.. hope some of that helps.
  3. graham.myers
    graham.myers
    Mar 11, 2003
    6,230
    Leeds
    +931
    I use a router. I plug the cable modem into the router and the the pc, laptop and xbox in to the router
  4. tony kop77
    tony kop77
    Sep 27, 2002
    6,169
    103
    Northamptonshire
    +276
    I was not sure if I could just unplug the ethernet lead from the PC when not in use and just connect my xbox ethernet instead. I thought I had to pay the £5 because apprantly I have to register the xboxs MAC address with NTL.
