How do I connect my xbox to my amp
Discussion in 'Xbox Forums' started by ftogpx, Nov 3, 2005.
  1. ftogpx
    ftogpx
    Hi guys, sorry for my complete lack of knowledge on this subject. My xbox is currently connected to a 21" Sony 4:3 tv with a single crappy speaker. I've got my old (non av) amp and speakers gathering dust in the attic, and wondered if i could have the sound coming through these speakers instead of the tv ones. How would I go about doing this? My tv only has one rgb scart (which the xbox is connected to) and two composite video/audio inputs on the front.
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    I'm not sure which scart cable you're using. I believe the official advance scart cable has seperate connection for red and white stereo audio cables. You coud get these cables and connect them to the amp for better sound. Alternatively companies like Joytech make Xbox scart cables with seperate stereo audio cables that can be connected to an amp. This is all assuming your amp isn't capable of surround sound.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    23,034
    London
    +1,157
    If you get the high-def av pack, then you can connect your xbox to the amp using an optical cable which should give you 5.1.
  4. John
    John
    Dec 13, 2002
    11,724
    +3,424
    You'd be looking for the advanced scart , rather than the HD pack , for your Sony :D
    Theres a few in the Classifieds at the moment ;) :D
    John
  5. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    And the cable you'll be needing is called a "toslink" optical cable ;)
  6. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,963
    2
    2
    Manchester
    +4,475
    Hang on - he does not want an optical cable at all - he says his amp is non-AV, ie. stereo only.
    Therefore what he needs depends on if his tv has stereo out RCA (red and white) - if so, just get a standard 2x RCA to 2x RCA to connect the tv to the amp. If not then he'll need to see if there is such a thing as an RGB scart with stereo out (2x RCA) - I would've thought there'd be a 3rd party one somewhere.
  7. John
    John
    Dec 13, 2002
    11,724
    +3,424
    Not so lorenzini ;) . If he is using the standard supplied cable with his xbox , then he only need to unplug the red and white cables , and plug these into an available input on his amp . Leaving the yellow composite cable pluged into the scart adapter , into the scart socket .
    John
  8. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    I don't know what you all are on about. I already mentioned what he needs in my post. You're just confusing him. Try and read what some has posted before responding. :eek:
  9. ftogpx
    ftogpx
    Thanks for the help everyone :thumbsup: Yes, i've just got a normal stereo amp. My xbox lead has the red/white/yellow connectors that plug into an adapter and then into the scart socket on the tv. So basically i just take out the red/white connectors from the adapter, connect them to the amp and leave the yellow one attached. Thanks
  10. Tejstar
    Tejstar
    Dec 4, 2002
    23,034
    London
    +1,157
    Yep that will work! :thumbsup:
