how do i connect my home cinema to the sky box
Discussion in 'Home Cinema Buying & Building' started by steviemac@ire, Sep 16, 2005.
  1. steviemac@ire
    steviemac@ire
    hi all..just bought myself a panasonic SC-HT530 home cinema system to use with my TH42PV500 when it gets here and ive connected it to the tv i have at the moment..im new at this and im a little confused on how i can get my system to work with my sky+ box..at the moment ive got it into one of the scarts on my tv but can only use the system when im watching a dvd..can i connect the ht530 to the sky+ box? if so can anyone tell me how and what cables i should use as the system only has one scart on it and at the moment ive got it in the tv..thankyou stevie..belfast :lease:
  2. Neiliboy
    Neiliboy
    May 13, 2003
    204
    16
    Cambridge
    what inputs do you have on the back of the Home Cinema system?
    I think you should have an optical output coming out of your Sky+------>linked with a 1Metre optical cable ---------> into the back of your panny system.
    You will have a problem if your panny has a co-ax in with no opitcal though
    HTH
    Neil
  3. steviemac@ire
    steviemac@ire
    hi neiliboy thanks for the info..had a look at the back of the sound system and there is no optical output on there..i have some red and white plugs with tv audio and component plugs do you know if i can use any of these to do the job..thanks again stevie..belfast
  4. nightsoil
    nightsoil
    Sep 12, 2004
    247
    +3
    Most sky boxes have normal phone stereo outputs and these should be connected to your SC-HT530 TV inputs.
  5. steviemac@ire
    steviemac@ire
    thankyou very much nightsoil...will have a look at that..will i just need some phono to phono leads?...sorry im new to all this..
  6. nightsoil
    nightsoil
    Sep 12, 2004
    247
    +3
    Yes - normal phono leads will do the trick..
  7. steviemac@ire
    steviemac@ire
    :thumbsup: thankyou for your help... :beer:
  8. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    but with normal phono leads you will only get dolby pro logic and not 5.1, there is a device you can get that converts optical to co ax, dont know much about it, just read someone else on the forum doing the same,
    i dont understand why a manufacturer would make a theatre system without optical, as it seems wider used than co ax....
  9. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
  10. steviemac@ire
    steviemac@ire
    :thumbsup: thankyou ill have a look at that..
  11. tim1964
    tim1964
    Jan 9, 2005
    28
  12. bobmeister2k
    bobmeister2k
    Sep 21, 2005
    114
    +5
    Tim (or anyone that knows!), I am in the same situation as the original poster (PV500, SCHT530)
    What cables would I need to go with the Maplin product, and would this then allow 5.1 on sky+?
    Thanks a lot
    Rob
  13. bigdalkabir
    bigdalkabir
    Sep 16, 2005
    15
  14. CatDog
    CatDog
    Apr 20, 2001
    94
    Midlands
    Hi StevieMac, I'm thinking of getting these two boxes - did you get them to work together properly ? Can you get 5.1 sound from the Sky box ? Thanks.
  15. The Barndog
    The Barndog
    Jun 23, 2005
    3
    +3
    Does the SCHT 530 have a co ax input? Anyone?
