how do i connect game system to amp
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by The Sheriff, Nov 26, 2004.
  1. The Sheriff
    The Sheriff
    Jan 2, 2003
    449
    Goch, Germany
    +6
    i have an xbox and would like to put this in my car, ive got the suitable battery system and all leads apart from ive been told that the frequencies are different. On subs they use pre-in and the xbox uses a line out (or vice versa). how do i get round this, any sort of convertor i need
    many thanks
  2. jtf
    jtf
    Nov 19, 2004
    220
    colchester
    +7
    from what i understand you only want to sort out the audoi side of things. there are 2 ways 1, if you headunit has a line in you can use the preouts from the x box and feed them directly into the headunit or 2, buy an rf modulator. this will convert your preouts from the x box to an rf signal which you feed into the aerial socket on your headunit
