How do i connect for TV use
Discussion in 'Plasma TVs' started by mrfreeze, Jun 12, 2004.
  1. mrfreeze
    mrfreeze
    Hi All
    I'm hoping somebody can point me in the right direction.
    I have just acquired a 2nd hand Fujitsu plasma. Stunning pics via my dvd through the SVHS socket, but now comes the tricky part.
    The screen is only equipped to accept signals via SVHS (1 only) or by BNC connectors through either video, composite video, RGB etc. I already have a Digibox with only a standard RF out or scart out.
    Is it actually possible to connect this to my plasma tv receive terrestrial tv broadcasts or do i need a standalone tuner. If it is possible which is the best way to do it.
    Also what connection will yield the best picture from my dvd, this has RGB, composite video & standard video & SVHS uot.
    If anyone can help i would much appreciate it.
    Cheers :thumbsup:
