How do I connect everything up ?
Discussion in 'Cables & Switches' started by SilverJDM, Oct 2, 2004.
  1. SilverJDM
    SilverJDM
    Aug 23, 2004
    362
    28
    Amsterdam, Netherlands
    +77
    Hi All.. Yet another newbie needing help from you knowledgeable people..
    I have just moved home & had Sky+ installed, I can't find the the piece of paper with how to re-connect my system... So can anybody help :lease:
    I have:
    Sony TV - KV36FS70/U (3 scart sockets)
    Sky+
    Panasonic VCR (S-video equipped)
    Sony Home Cinema - DAV-S800
    IXOS leads - 2 x scart to S video / 2 x scart to scart
    + 1 additional lead (I think this is audio, 1 red, 1 white plug each end)
    How do I connect every thing up ??
    JDM
  2. BrianC
    BrianC
    Jan 20, 2003
    2,199
    +101
    Hook up the Sky+'s audio digital output using a TOSLINK cable to the Sony Dav's matching input. This will give you 5.1 for those sky channels that support it, a cheap £5/£10 optical lead is all you need.
    Hook up the analog audio inputs from the Sky+ box to the Sony Dav, this will give you sound from both the TV and the Video.
    Plug in the video into the VCR input on the Sky+ box, and plug the Sky+'s TV scart output into the TVs first scart socket. Make sure the Sky+ box is set to output RGB via the setup menu on the Sky+ box.
    Plug in Sony Dav to the TVs second scart socket using one of the s-video cables.
    Job done.
  3. SilverJDM
    SilverJDM
    Aug 23, 2004
    362
    28
    +77
    Thank you :thumbsup:
