oxfordyankee
I will be getting a Media Center PC with DVI, Component and VGA connections available on it.
I want to connect it upto my Pioneer but am looking for some advice as to the best way to connect the two. Currently I use the HDMI port to connect back to my AV amp which has the other source devices on it. The 434 does have a dedicated VGA port on it to connect to a PC and it seems that would be the best bet.
Does anyone have any advice, tips etc as to how to get the best connection between the two?
Many thanks
Nick
Many thanks
Nick
