How do I connect a Sonos Playbar to a Panasonic GT30
Discussion in 'Home Cinema Speakers' started by mattcafc, Aug 26, 2013.
  1. mattcafc
    mattcafc
    Mar 11, 2007
    457
    +19
    I've got a Sonos playbar and a Panasonic GT30b TV. I've just tried to connect it and found out the sonos uses an optical out lead and the Panasonic has an audio out connector.
    Is that different? If so, is it possible to connect with some sort of adapter?
  2. spyder viewer
    spyder viewer
    Dec 18, 2007
    5,846
    2
    Kent, UK
    +1,285
  3. mattcafc
    mattcafc
    Mar 11, 2007
    457
    +19
    Hi, no that's not the same. The port on the back of my tv says digital audio out and is a little square port. Like the optical port on slightly different size
  4. mattcafc
    mattcafc
    Mar 11, 2007
    457
    +19
    Sorry the port on the tv is round
  5. Jaunty
    Jaunty
    Feb 7, 2006
    2,483
    83
    London
    +297
  6. Jaunty
    Jaunty
    Feb 7, 2006
    2,483
    83
    London
    +297
    Did it help? At least if you replied it would help other people with a similar problem.
  7. ranjb
    ranjb
    Aug 26, 2007
    81
    11
    I have a GT30B and connected a playbar without issue. You need to use the optical digital adapter cable you got with the panny and connect to playbar.
    Simples!
