How do i connect a DVA500 & PE30?
Discussion in 'Cables & Switches' started by Froggins, Oct 18, 2004.
  1. Froggins
    Froggins
    Can someone help me?
    I'm taking delivery tomorrow of a Panasonic PE30, i going to connect it to my DAV500 surround sound system!
    I know the TV has scart/composite etc buti have had a look at the DAV system and it looks like it only has the following:
    Video Jacks in & out/digital in/optical out & SVideo?
    What do i use?
    Please help! :lesson:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK mate you a S-Video and Audio (audio if you want to use TV speakers) TO scart cable..
    One of these http://www.tvcables.co.uk/cgi-bin/tvcables/PGV632.html is just the ticket connect to one of the S-video scarts on PE30 (AV2 IIRC is suitable) Set DAV to output S-video if necassary and set AV2 to S-Video input (Coloured button option IIRC)
    To use DAV for TV sound IE FV or anaolgue tuner you will need to run something like this http://www.tvcables.co.uk/cgi-bin/tvcables/PGA4201.html from TV Audio out sockets to an analogue input on DAV system....
  3. Froggins
    Froggins
    Horneydragon, thanks for the tips as it is much appreciated!
    Being a bit of a doughnut about av stuff, i'm not asking for much but i want the best possible picture and use the DAV system for sound?
    Is it the same cables you said or is it a different setup??
    Thanks for your helpmate!! :hiya:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    unless DAV has YUV output go as above
