How do I configure Digital audio Source and S-Video
L
Londonrich
I have a Tag DP.
My satalite now has a digital 5.1 output and hence I want to do the following:
Use my existing S-video satalite signal.
Use the digital SPDIF audio signal connected to the CD input socket on the tag
When I select the Satalite video signal I want it to use the CD input audio to get the 5.1.
I have looked at the manual and cant work how to do the above -does anyone have any suggestions.
L
Londonrich
Sorry just to clarify - I want to be able to do the above with one button - ie when I press satalite the default sound is the digital input - I know I can scrowl through the inputs but I wanted a default solution.
lovegroova
Enter the menu and select Change Setup
Then select Input Options/PSM192
Then select Key Assigments on Remote
Then select whichever key you want to use for the Satellite,
Let's say you want to use the TV button to select your Satellite
Select Set tv/vcr/sat keys
Then select the TV and change AUDIO1 to cd
and change VIDEO to sat-s
That should do it. See p.62 of the setup manual for more details.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
