how do I clean the screen of my new viera :) ??
Discussion in 'Plasma TVs Forum' started by sanj666, Sep 11, 2004.
  1. sanj666
    sanj666
    Having just spent close top £3000 on my new tv
    can anyone recommend how I should clean the screen
    ie what type of cloth and what type of cleaning product? :zonked:
    thanks
    Sanj
  2. PhilipH
    PhilipH
    Oct 20, 2000
    167
    16
    Salisbury
    The stuff I use on all my screens (CRT / LCD etc.) is IXOS smear free spray gel (PCWorld for about a fiver) to clean the screen initially if it's got fingermarked.
    Then - even though it's supposed to be smear free it isn't so then I use a dampened sponge to wipe the screen over and then soft kitchen roll to buff up the screen.
    Phil
  3. peahead
    peahead
    Dec 14, 2002
    2,998
    St.helens
    +384
    I use plasmaclean its a antistatic screen cleaner comes with its own special cloth heard about it homecinema choice news page it cost me about £22 for 220ml bottle from here www.pc-com.co.uk well woth it. :hiya:
  4. quattro
    quattro
    Nov 30, 2003
    389
    Stafford
    +16
    I use a a micro cloth, can't recall the actuall name of it but its blue and sold in Wilko's cost around £2.99 and is excellent for all dusting especially glass. better after its been washed though as when new leave blue fluff for the first few uses when dry.
  5. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    BAD BAD idea. Common kitchen roll will leave fine scratches and swirls on your screen.
    The pro's choice is AF Screen-Clene Safe Clens. Or Sapona screen clean as a close second. You must use a lint free cloth/wipe.
  6. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,207
    n/a
    +292
  7. sanj666
    sanj666
    thanks for the advice guys
    i had a thought.....what about using the lens cleaning tissues I use on my camera
    lens, would that also be ok?
  8. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,619
    London
    +468
    Yes lens cleaning cloth will be fine.
    Those Plasma screen bottles at £20 are a complete rip off. Go for AF Screen Clene Safe Clens, a can of 250ml will be under a £5. It's what manufacturers will use anyway.
