Quantcast
How do I check what firmware a Denon 2900 is running?
Glenn Keen
I'm thinking of getting a Denon 2900, but I'm aware there are issues with the plyer that are fixed by later versions of the firmware.
My question is how do I check what version of the firmware it's running and what it the version it NEEDS to be running to fix the issues?
MANY THANKS for any Info.
Glenn.
D
diabolik
Have you tried using search? There's loads of stuff on here.
Glenn Keen
Sorry, i'm stuck at work & don't have time to search through a whole lot of stuff. I'll try to get on and do that later, unless some one can help me before then.
Thanks again.
Glenn.
