How do I check mobo BIOS version?
Discussion in 'Desktop & Laptop Computers Forum' started by Brogan, Jul 7, 2004.
  1. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    OK, another one for you gurus out there...
    I have flashed my BIOS but I'm not sure if it has worked or not... :confused:
    I have tried to see which BIOS version it is on boot up but can't see anything.
    Is there any way of checking which BIOS version is loaded to my mobo?
  2. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Got an answer from Epox on this: "The date of the BIOS will be shown at POST as 4th March 2003"
    What does that mean?
    What is POST?
  3. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    OK, found out what POST is but it happens before the monitor displays anything and therefore I can't see what version it is.
    How can I stop boot up after POST or at least pause it/slow it down?
  4. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,368
    Stevenage, Herts
    +151
    Two suggestions:
    1. Detach keyboard. It should halt because of missing keyboard, I'm not 100% sure it stops in the right place though.
    2. I think Sisoft Sandra has more detail than you would ever need about your PC. It's shareware or freeware in base version. As a lot of bios upgrades can now be done via Windows the bios details should be accessible from a decent util pgm.
    Steve
  5. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Thanks Steve.
    Already tried the keyboard idea but that didn't work.
    I'll download that utility and see what's what.
  6. Garrett
    Garrett
    Apr 21, 2001
    31,506
    2
    The best thief you’ll never see.
    +4,046
    Does CTRL, ALT, Pause Break work????
    As a last resort you could try videoing it.
  7. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    :rotfl:
    Unfortunately haven't got a video camera...
  8. Garrett
    Garrett
    Apr 21, 2001
    31,506
    2
    +4,046
    Regressive hypnosis. :laugh:
    Or digicam video mode?
  9. Garrett
    Garrett
    Apr 21, 2001
    31,506
    2
    +4,046
    Would disconnecting one of the bootable components (HD, Floppy or CD/DVD) slow it down long enough for you to read the info?
  10. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,096
    Manchester
    +711
    MSinfo32.exe (should be free with MS Windows)
    will report your bios version.
    Chris Muriel, Manchester.
  11. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Thanks for that Chris.
    I remembered after my last post that msinfo provides this information...
    Must try and remember that in future (again). :rolleyes:
    Looks like my BIOS update didn't work after all. :mad: :suicide:
