How do I check display output?
bluefoxtim
I have an LG 26LC2R and have been looking through the manual and the menus but cannot find anything.
I read quite often that people check what display mode their tv is in (resolution and 480i 720p etc)
How do I check this? There is an 'screen' menu but it is greyed out.
I don't have anything connected through HDMI or component, so is that the problem? Would the screen option become available if I used this connection?
:lease:
ijd
yes, only your component or hdmi will have higher resolution settings than your standard 520i, so if your running scart or composite it is set at the default resolution which is 520
bluefoxtim
Rightio. Thanks
The manual is pathetic. About 5000 pages, only about 3 are in english :eek:
