How do I change Sky channel from a different room?
Discussion in 'Sky Digital TV Forum' started by steve 111, May 6, 2005.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    I have my TV in the bedroom connected to my Sky+ box (thats in the room above my bedroom) using a 3m s-video cable. Although this set up gives be better picture quality than using RF, how do I now change channel from my bedroom?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    You need to use a Magic Eye connected to the RF2 out on the sky box.
    John
  3. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    John,
    Just so that i'm clear connect a Magic Eye to the RF2 out socket using standard satellite cable, and then don't bother to connect the Eye to the TV as I don't need to transmit sound or vision via the Eye?
    Steve
  4. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    That's right, standard coax from the RF out to the magic eye but no connected ot the TV. You need to switch the RF outlet 'on'. The magic eye comes with instructions but, to get to the option, press Services, 4, 0, 1, Select.
    HTH
    John
  5. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Cheers John, you've been a great help. :thumbsup:
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    steve thats exactly what ive done, magic eye from rf2, and rgb scart from one room to another and i have a glorious pic
  7. l200
    l200
    Oct 22, 2009
    2
    Im not very savvy with sky unfortunately, so at the risk of sounding stupid here goes.
    I have sky plus in one room and a magic eye transmitting the signal to another. but the screen in the second consistently flickers. is there anything i can do about this?
    Also is there anyway i can change channel is the second room?
  8. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    The magic eye has nothing to do with "transmitting" the signal to another TV. It is there purely to enable remote control of the Sky box.
    Do you still have the instructions that came with the Eye?
  9. l200
    l200
    Oct 22, 2009
    2
    ok i must be using the wrong term, We basically have a wireless transmitter which enables us to watch sky in a different room wireless, but i also want to be able to change the channel from this other room, is it possible?
  10. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,829
    +897
    Perhaps if you told us the make and model number we may be able to help.
