How do I change default settings to "16:9" for Loewe Mimo?
Discussion in 'TVs' started by chrisjoanne, Nov 20, 2003.
  1. chrisjoanne
    chrisjoanne
    Aug 19, 2003
    216
    I have just spoken to a chap from Loewe headoffice and he says if I want to change the default settings for the picture shape to 16:9 I must go through the engineer service menu. ie get someone out.
    I'm sure this has been brought up before but I can't find it anywhere - How do I get into the menu and how do I change the default to 16:9
    Also, do other Mimo users change the default or are there happy to watch a 4:3 broadcast on their 32" Tv?
    If a program is then broadcast in widescreen, it'll switch to 16:9
    I still can't decide if this is good or bad. If the program isn't broadcast in widescreen I suppose it should'nt be shown in widescreen !
    This is my only "fault" to date - but like the guy said - it can be changed so I'm still very happy with the Tv
    Chris
  2. lewden
    lewden
    I like watching all broadcasts in the aspect ration they should be shown in, so I leave the AMD setting to on and I let the loewe do the work. Its never caused me a problem - the resizing is very smooth and subtle in my eyes. The thought of watching 4:3 in 16:9 doesn't appeal.
  3. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    To my eyes watching 4:3 material stretched to 16:9 looks very odd. I find the resized "Pan" option to be a good compromise so i just leave the set in this mode. It will then switch to 16:9 when it needs to.
  4. bazzae123
    bazzae123
    Mar 10, 2002
    314
    16
    I like to leave the set in 4:3 and it them switchs to 16:9 when it needs to.
    Bazza
