How do I bi-amp with AV32R and 100x5R?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by eisenach, Mar 12, 2005.
Tags:
  1. eisenach
    eisenach
    Jan 11, 2005
    192
    Herefordshire
    +7
    I've just succumbed to HiFiBitZ' offer, and with luck should be getting this combination. At the moment, my system pure stereo, with the B&W speakers bi-amped, and I'd like to use the 100x5R to carry on doing this. Looking up on TAG's website, the AV32R only seems to have one set of outputs, though, and the 100x5R doesn't seem to have the facility to pass the incoming signal on from one amp module to another.
    I've read on this forum that some of you do bi-amp using the 100x5R - how do you go about splitting the signal from the preamp to feed two modules?
  2. NeilS
    NeilS
    Nov 16, 2001
    216
    Essex
    +8
    You need to use a phono splitter to provide 2 frrds from the single outputs of the av32r.
    Don't forget to remove the bridging pins from the speakers too!
    Neil
  3. eisenach
    eisenach
    Jan 11, 2005
    192
    Herefordshire
    +7
    Can I use a splitter at the amp end and use a flying lead to feed the signal over to an adjacent module - or even better, get a lead made up combining the feed and the flying lead into one phono plug at the amp?
  4. derekn
    derekn
    Jun 8, 2004
    717
    28
    Bristol
    +38
    I use a solid splitter - one phono plug to two phono sockets with my subs. No room for it on the AV32 so I fit it to the first sub and then link AV32 to Sub to Sub :smashin: . Checked with REL before I did it - plan to do the same with my L&R Fronts when I get my new amp.
    Regards,
    Derek
  5. Inotrope
    Inotrope
    Dec 23, 2004
    689
    Nottingham
    +44
    Could someone post a pic of this to make it clear for me....
    Also, are you not doubling the impedence of the amp output? Is there any influence on volume (or unlikely but, sound quality?)
    Thanks, mark
  6. Inotrope
    Inotrope
    Dec 23, 2004
    689
    Nottingham
    +44
    Oh, its the fronts I wish to bi-wire, with the 100x5, using the AV32R (obviously!).
  7. derekn
    derekn
    Jun 8, 2004
    717
    28
    Bristol
    +38
    Mark,
    I checked with roversd1 who said it would be ok to biamp TAG kit (and he should know), he said that some found it increased headroom - try it and let us know.
    Derek
