How do I adjust audio delay....
Discussion in 'AV Receivers & Amplifiers' started by jetfitzmaurice, Dec 29, 2006.
  1. jetfitzmaurice
    jetfitzmaurice
    Oct 22, 2005
    3
    Sidmouth, Devon
    Hi, I just got a Denon AVR1907 under the tree :thumbsup: I've used the auto set up with the mic and it sounds great but I do seem to have some lip sync issues ( as i did with my old amp, marantz sr4200) however i notice the Denon has "Audio Delay Function (0 - 200msec.) Audio delay function corrects slight lags between sound and picture that can occur when a video signal is processed, such as in a Progressive Scan DVD player or outboard video processor." How do i adjust this? does anyone know, I've looked through the manual so many times, I'm either blind, stupid or both :( hope you guys can help
  2. Jase
    Jase
    Mar 16, 2001
    10,873
    United Kingdom
    +3,041
    It's in the main setup menu. You need to go into Video Setup, Audio Delay then make the relevant adjustment. Make sure you're on the Input that you want to adjust(e.g DVD) before you press the button to get the menu up.
  3. Tsunami
    Tsunami
    Jul 22, 2005
    211
    +7
    You should also be able to do it from the remote (from memory) you press the down arrow (or the up if down doesn't do it!) & the digi display will show the delay you can then press left or right to adjust the sync & press ok. This way you can alter the sync while looking at the picture.
  4. jetfitzmaurice
    jetfitzmaurice
    Oct 22, 2005
    3
    Sidmouth, Devon
    Thanks peeps, all sorted :smashin: hope you have a great new years
