How do I add an NTL cable box
Discussion in 'Cable TV & Virgin Media TV' started by JFDI, Sep 19, 2004.
  1. JFDI
    JFDI
    I have a standard NTL cable installation which goes to the usual General Instruments black box.
    I would like to install another box (which I already have) in a spare bedroom.
    Has anyone done this?
    Idiot's guide gratefully accepted.
  2. Nelviticus
    Nelviticus
    Jun 21, 2003
    469
    Hitchin
    +68
    I think that the engineers have to come out, drill another hole in your wall and put in a new cable point. That's what they had to do here when I wanted an internet access point upstairs.
    A possible solution may be to get a Digisender Gold which I believe Argos are selling. That will relay the sound + video from your existing box to your spare room and transmit your remote control signals back the other way. The main downside is that you can't watch different things in different rooms.
    Regards
    Nelviticus
