ucfmotorcycle
I have a Samsung Frame TV and S61 soundbar. They work well together through an HDMI cable and ARC input.
I would like to add an analog subwoofer that I have but there are no analog outputs on the TV or soundbar.
I tried an optical to RCA converter but then the soundbar would not work through HDMI plus there was no way to modulate the volume on the subwoofer other than manually adjusting the amp attached to it.
I also tried an HDMI ARC audio extractor from Amazon but that just didn’t work at all. It seemed like it should. Perhaps someone can recommend one that works with this setup?
I’d like to basically be able to modulate volume through the ARC feature and add an analog output so I can plug in this subwoofer. I have been searching all over for something that I can add to make this work but I can’t.
The soundbar itself only had outputs via WiFi or Bluetooth. Is there a Bluetooth receiver with analog out that could work?
