How do I add a third digibox?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by steve 111, Dec 28, 2003.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    I've currently got Sky + in the lounge and my original Digibox in my TV room. At present i'm running my TV in the bedroom off a 'Eye', but would rather just add another digibox. What would be the best way to do this?
  2. chilpillphil
    chilpillphil
    for £150 inc installation sky will provide a pace mini box, only has one scart, no rgb output, and no photo audio sockets
    extra subscribtion will cost £10 per month,
    search the net on www.sky.com
    or if you wanna buy one there cheap at the momnet, or you can buy a panasonic 31 - off my for £60
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=3067576688&category=29784
    for an image.
    then you just ran a cable from you LNB to the new box, and ring sky for a viewing card, that will be cheaper and you will get a better box than the minibox.
    its your choise, obviously
  3. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,611
    48
    Lancashire
    +51
    Steve111, buy Sky+, they'll install the quad LNB - you need a 'wire' from dish to each box. Most systems have dual LNBs on the dish - 2 outputs for 2 boxes. A quad LNB has 4. Sky + uses 2. I imagine you've only 2 eyes, so you will struggle to watch more than one program at once. You can watch 1 record another, & a 2nd person can watch on 1 of your other 2 boxes. If you keep the link you'll still have 4 viewing locations, 2 independant boxes, +, allowing you to recor, watch at once. Sky + is great, its got my viewing to 20 hrs a day, after this I'm struggling to find anything to watch. I've got some DVDs for christmas though. If it doesn't improve I'll be watching some old videos!
  4. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,611
    48
    Lancashire
    +51
    Gosh I should read the post before replying!!!!!!!
