How do I add a DVD player to this lot?
Discussion in 'Blu-ray & DVD Players & Recorders' started by e46_m3, Jan 4, 2007.
  1. e46_m3
    e46_m3
    Mar 7, 2006
    202
    Nottingham
    +4
    Below is my current setup - I want to add an HDMI upscaling DVD player which will then replace the DVD function of my cinema system but I still want to use the surround sound on the Panasonic and am not entirely sure how to add the DVD player.
    Do I simply need to unplug the DVD RGB connection from the DVD player to the switch (but leave the optical connection so I can still switch that as and when I need to) and just plug the new player into the HDMI socket on my TV to enable my setup to work as it does currently for the existing equipment with the addition of being able to use my surround sound system with the new HDMI DVD player?
    Jase
    TV (LG 50PX4D)
    Scart to Sky+
    RGB to Output of switch box
    DVD player/Cinema system (Panasonic SCHT900)
    Optical to optical port on output of switch box
    RGB to input three on switch box
    XBox 360
    Optical and RGB to input one of switch box
    Sky+
    Scart direct to TV
    Optical to input two of switch box
