How do I access 'Wide-Screen' mode on Xbox games such as Halo?
Discussion in 'Xbox Forums' started by tk2001, Feb 4, 2002.
  1. tk2001
    tk2001
    Nov 4, 2001
    1,402
    48
    +36
    Hi, I recently got an Xbox and the two gamess I've got for the system is Halo and DOA3.
    When I play my games on my wide-screen TV, the image seems scretched resulting in characters looking more fatter than usual.
    Are there options in the games that enables you to play your games in 'wide-screen'?
  2. chicken balti
    chicken balti
    Check out the start up (green) screen, you can set the aspect ratio of your TV in there. Your TV may not auto-adjust to widescreen as soon as it gets the video signal from your XBOX but you should be able to manually select the ratio of the TV to get a perfect picture. Game on.
  3. brattle
    brattle
    Oct 12, 2001
    108
    16
    Bedford
    Note that not all X-Box games have 16:9 modes. Here is a list of the most common titles and whether they have a 16:9 mode or not. If they don’t, then the game will default to 4:3 whatever mode you use.
    AMPED: Freestyle Snowboarding - Yes
    Yes Azurik : Rise of Perathia - Yes
    Batman - No
    Bloodwake - No
    Cel Damage - No
    Dead or Alive 3 – Yes
    F1 2001 - Yes
    Halo - No
    Madden 2002 - Yes
    Max Payne – No
    Nascar Heat – Yes
    Nascar Thunder – Yes
    NBA 2002 - No
    NFL 2K2 – No
    NFL Fever 2K2 – No
    NHL 2002 – No
    NHL Hitz - No
    Oddworld: Munch's Oddysee – No
    Project Gotham Racing – No
    Shrek - No
    Silent Hill 2 - No
    SSX Tricky - Yes
    Star Wars Starfighter - No
    Tony Hawk 2x - No
    PG’s predecessor on the DC did have a 16:9 mode that was unlocked by completing certain parts of the game. I haven’t heard that PG has the same.
