how difficult is it to fit a relay switch on a cheap electric screen
Discussion in 'Projectors, Screens & Video Processors' started by the blue angel, Jun 20, 2005.
  1. the blue angel
    the blue angel
    May 20, 2005
    119
    16
    i want the 12 volt trigger on my invocus screenplay 4805 to switch on a electric screen i cant afford a expensive screen with a 12 volt built in trigger
    is there anyway around this for cheapest solution thanks guys
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Owl Video do an inexpensive trigger board.
    Very easy to fit, just make sure your screen has a 240v motor and fit it instead of any manual switch.
